Disabling automatic keyframe creation...
COW Forums : Boris FX Particle Illusion
Peter Kovacs
on Jan 20, 2013 at 1:46:41 am
Is there a way to adjust a value without it creating a keyframe? Often I'm just experimenting with values, playing it back to see how it looks, etc. So I would then end up with a tonne of keyframs at different times, it's a mess.
It would be cool if I could adjust a value no matter where I'm at on the timeline, and only create a keyframe if I tell it to. This is exactly how After Effects works.
Alan Lorence
Re: Disabling automatic keyframe creation...
on Jan 21, 2013 at 3:32:47 pm
pI doesn't work like AE as you've found.
If you want to experiment with changing the value without creating a keyframe, grab the last keyframe (most likely the one at frame 1) and drag it around.
Alan.
Alan Lorence
Product Manager
GenArts, Inc.
http://www.genarts.com
http://www.wondertouch.com
