Output PNGs from PI Render are squashed
COW Forums : Particle Illusion
Marco Rosenberg
on Aug 10, 2012 at 9:49:57 pm
Hi there,
I have a problem with particle Illusion Render:
I tried to render PNGs of an Effect in Full HD (1080x1920) and the PNGs are squashed in width.
The strange thing is, if I open them in Windows Picture Viewer, they pop up at the correct aspect ratio for half a second and then squash to square shape.When I import them into After Effects, they are also squashed.
I tried the same with a custom aspect ratio like 1500x1200, but that also resulted in squashed PNGs.
Is there any setting or workaround to avoid this or is it a bug?
Kind regards,
Marco Rosenberg
Alan Lorence
Re: Output PNGs from PI Render are squashed
on Aug 11, 2012 at 2:46:06 am
If you load the PNGs back into particleIllusion as a background image, is the aspect ratio correct?
Perhaps there is some aspect ratio info being written incorrectly into the PNG files. Try saving as TGA -- does that fix the problem?
Alan.
Alan Lorence
Product Manager
GenArts, Inc.
http://www.genarts.com
http://www.wondertouch.com
