AutoUpdate Error Message
COW Forums : Boris FX Particle Illusion
Tony McDermott
on Jul 14, 2012 at 9:51:03 am
I've just recently downloaded Particle Illusion SE, after having to renew my activation count.
When I open Particle Illusion, and go to "Check for updates" and then "Download and Install" all emitter
libraries, I get a dialogue box titled: "AutoUpdate Error" containing the error message: "Bad zip item - 65536"
Can anybody help me with this?
4403_particleillusionerrormessagescreenshot.jpg.zip
Alan Lorence
Re: AutoUpdate Error Message
on Jul 16, 2012 at 1:58:17 pm
I think you need to login as administrator, or r-click on the particleIllusion shortcut and "run as administrator", then try the update.
Alan.
Alan Lorence
Product Manager
GenArts, Inc.
http://www.genarts.com
http://www.wondertouch.com
Tony McDermott
on Jul 16, 2012 at 7:56:16 pm
I've re-installed Particle Illusion, restarted my PC and ran Particle Illusion as Administrator, however, I still get the same error message, I can't think what it could be.
Alan Lorence
on Jul 16, 2012 at 8:20:05 pm
Were you logged in as admin, or did you use "run as admin..."? Try both if you haven't.
If that still doesn't work, just download the emitters from the wondertouch website and unzip them manually.
Alan.
Alan Lorence
Product Manager
GenArts, Inc.
Tony McDermott
on Jul 16, 2012 at 9:12:35 pm
Will do, how do I Login as Administrator?
