Emitter question for Tom or Alan
COW Forums : Particle Illusion
Bob Moyer
on Apr 11, 2012 at 2:19:13 pm
Win7/pI 3.0.4.3/emitter library 12_01.il3
I have added HUD Air 2 Air 2 to my stage (720 x 480) and reduced the size to fit on my stage. The number portion of the two emitters "Angle" and "Alt" continue to scroll past the top of the emitter and do not disappear until they scroll off the top of the stage. In other words, how can I get them to stay contained within their respective green boxes. Hope that is clear. Thank you.
Bob
Alan Lorence
Re: Emitter question for Tom or Alan
on Apr 11, 2012 at 2:24:51 pm
How did you reduce the size to fit your project? If you used the "zoom" parameter it should work fine. If you used "size" that's the mistake. Size just changes the size of particles, while "zoom" changes size and velocity. Zoom is equivalent to "scale" in most apps, while "size" is just particle size.
Hope that helps.
Alan.
Alan Lorence
Product Manager
GenArts, Inc.
http://www.genarts.com
http://www.wondertouch.com
Bob Moyer
on Apr 11, 2012 at 2:33:26 pm
Boy! Talk about quick response time...I am impressed. You guessed correct I used the size parameter and the zoom works much better. Thanks again.
Bob
laura newell
on Apr 12, 2012 at 4:03:49 pm
hi not sure if right place but im trying 2 create effects,successfull till render,effects not rendering i did get new pc,with ati 6200 hd something card,i tryed tweeking seeting as no effects will render nothing,trying reinstall any other suggestions
