Disable automatic pIllusionRender call for oversized renders
COW Forums : Particle Illusion
Kevin Kipper
on Sep 22, 2011 at 7:08:05 pm
Hi Alan & forum members,
It use to be possible to render whatever was viewed on the screen at the maximum resolution of the screen, but now if I scroll around on my stage and then try to render at 100% (part of my stage is offscreen) the pIllusionRender is called with it's software (default) settings. What I really want is to use the hardware render to render what I see on my screen. Is there a way to bypass the call to pIllusionRender in this case?
Kevin
Alan Lorence
Re: Disable automatic pIllusionRender call for oversized renders
on Sep 22, 2011 at 7:15:50 pm
No, it always tries to render the full stage extents. pIRender uses hardware acceleration too, so are you concerned about speed? Or do you really just want to render a portion of your frame for some reason?
You may have to reduce your stage size and reposition things if you really want to do this.
Maybe setting stage zoom to a lower setting?
Alan.
http://www.wondertouch.com
