Export Options or SDK?
COW Forums : Boris FX Particle Illusion
Kevin Bass
on Sep 19, 2011 at 9:20:26 pm
Hello,
I am sure I probably already know the answer to this question as you would more than likely include this information on your product features but I will ask anyway. Is there a way to do any of the following with Particle Illusion:
- Export the data for effects a user makes in some generic format such as XML, Text, etc.?
- Do you have an API/SDK available to allow third partys to load/decode .IP3 files?
- If no to both above is it possible to get the file format so that one could decode the file?
I would like to use your software to create particle effects but would like to use them in my own software/rendering engine. Is there anyway to use this in my own applications instead of using a sprite sheet or avi?
Thanks.
