Simple particle effects
COW Forums : Boris FX Particle Illusion
Jeremy Reed
on Sep 5, 2011 at 6:16:15 am
What is the simplest particle effect that I can create with After Effects? I am very new but I would like to learn to do this.
Thank you
Alan Lorence
Re: Simple particle effects
on Sep 6, 2011 at 1:45:58 pm
You mean with After Effects alone, or with particleIllusion in After Effects?
With particleIllusion, load the "blank" emitter library. It contains a "default" emitter. Also, the second emitter in the "Default" library is called "Simple Sparkles" -- it's pretty basic.
If you're talking about After Effects alone and not particleIllusion, you posted in the wrong forum.
Alan.
http://www.wondertouch.com
Jeremy Reed
on Sep 6, 2011 at 8:53:03 pm
Oh! I posted in the wrong forum. You see, I have an assignment in my After Effect class to post here. The point of the assignment is to familiarize myself with the CreativeCow forum. Thank you. Next time I will look more carefully at the categories listed.
