PNG is rendering poorly Bad TV lines-AVI also
COW Forums : Particle Illusion
randal radabaugh
on Mar 11, 2011 at 7:19:10 pm
I have used PI3 many times. have rendered using PNG alpha with BG removed.
never had an issue with any images- used in Sony and AE with
good results for couple of years. just a few weeks ago it was fine.
All of a sudden, any PNG seq. is rendering out very poorly
I get faded lines,bars almost like a bad TV effect.
I also got PI plug in for AE- if I use it in AE it looks fine,
but using PI3 alone is more versatile than plug in so I use it to
edit,change emitters-
have looked thru many many past posts and cant find the answer.
Some help please...
have tried every codec and avi files do it too.
okay this is getting weird.
I have rendered a single frame (same frame 3x) get a different hue on each, and on 2 I get full view render, and 1 I get the PI renderer. all PNG save alpha no Black BG and no BG at all.??
Alan Lorence
Re: PNG is rendering poorly Bad TV lines-AVI also
on Mar 11, 2011 at 11:17:57 pm
Does JPG work?
Try using "run with software rendering" in the Start menu. If that works, then it's a video driver issue.
Alan.
http://www.wondertouch.com
randal radabaugh
on Mar 11, 2011 at 11:56:37 pm
Thank you for replying.
okay jpg looks fine
did some things -am not sure what, but it has improved slightly,
instead of contrast lines, it is more pixelated.
Should not be any comp problems- I just got it back from PC shop 2 weeks ago.
Start menu? run with software rendering. where is this? <<
see dont show warning for software rendering in preferences.
but no use software rendering.
I reset to defaults- seems to have helped.still not High quality but much better than it was.is not Bad TV now :-)
still would like to know where this use software rendering is.
have looked thru app menus,open GL,pref, proj settings etc.
thanks Randal R
Alan Lorence
on Mar 14, 2011 at 7:23:03 pm
In the Start menu.
Start - All Programs - particleIllusion 3.0 - troubleshooting
Alan.
