Extreme Emitters- image sequences-change/swap images
COW Forums : Boris FX Particle Illusion
randal radabaugh
on Mar 11, 2011 at 4:48:17 am
hello.
Been using PI3 on/off for almost 2 years, and recently got it for AE also.
tbh, I never noticed the extreme emitters till now.
have been looking all over for the answer to this:
how to change the image sequence images in the extreme emitters?
changing out/adding an image gives a single image- where as some defaults
runs through 1-30.1-10 or none with multi images.
cannot locate the default images in it either to swap.The video link on changing is not
helpful.As an example- the Xray pulse 2.
from this reply and link
http://www.wondertouch.com/forum/index.html
or this one
file:///C:/Program Files/particleIllusion_3/Pro Emitters Manual/extreme_graphics.htm
The Xray pulse2 has multiple images but no number seq
- how do you add multiple images to the sequence? as in replace defaults?
Also, on the ones such as fast numbers/letters that have numbers 1-10, 1-30 etc
how do you swap out those images with different ones.
default runs thru 1- 10 numbers. if I change/add image it flashes that 1 image 10 x?
so if I have 10 images I want it to use- how?
any links,tuts, answer would be "EXTREMELY" appreciated.
also, keep seeing emit at points? have not found this parameter anywhere yet.
Thank you.
randal radabaugh
Re: Extreme Emitters- image sequences-change/swap images
on Mar 11, 2011 at 4:54:52 am
I think I may have found answer , but have not tried this out yet.
strange, every time I get to the point of asking, I find it.
http://forums.creativecow.net/thread/23/861157&remote_logo=wondertouch.gif&...
http://forums.creativecow.net/readpost/23/860647&remote_logo=wondertouch.gi...
will try this out.
