Quick Load Library not working
COW Forums : Particle Illusion
Reber Clark
on Feb 28, 2011 at 6:13:23 am
Since moving my emitters libraries to a secondary D: drive (not external) there are no libraries listed in the "Quick Load Library" menu. They show up in the Library Manager and are loadable with the "Load Library" menu. As a test I added an emitter to the emitters folder on the C: drive (primary drive) and it does show up in "Quick Load."
My questions is - is there a way to have the emitters from my secondary drive show up in the "Quick Load" menu? Thanks.
In theory there's no difference between theory and practice - but in practice there is.
Alan Lorence
Re: Quick Load Library not working
on Feb 28, 2011 at 2:33:43 pm
No. In the current releases only the "Emitter Libraries" folder in the application folder is used for the Quick load library menu.
Alan.
http://www.wondertouch.com
Reber Clark
on Feb 28, 2011 at 3:51:08 pm
Thank you Alan, I thought so. And thank you for hanging in there with me on that extended support issue I had a week or so ago.
