Library Trees
COW Forums : Particle Illusion
Reber Clark
Library Trees
on Feb 26, 2011 at 9:04:28 pm
I have two old locations for emitters, in addition to the location I use, showing up in my Manager Library Tree window.
How can I delete these old library paths? I see how to add a new path but not how to get rid of old ones.
Thanks.
In theory there's no difference between theory and practice - but in practice there is.
Reber Clark
Re: Library Trees
on Feb 28, 2011 at 1:25:44 am
Figured it out. While dealing with other pI3 issues I deleted these libraries OUTSIDE of pI3. That was the mistake. Therefore the "delete library path" button did not show up in the library manager and I was stuck. My solution was to re-add the library paths - each with a copied emitter in them - outside of pI3. Then in the library manager the "delete library path" button appeared and I could delete those paths. I then deleted the folders form my hard drive.
