white border at the right side of the image
COW Forums : Particle Illusion
Imre Fazekas
on Feb 21, 2011 at 11:01:59 pm
Dear All,
I have a serious problem. When i export a scene or a single frame to png or movie or whatever and i want to save the transparency too, the last column of the image(s) is white.
Even if i create a new project (512x512) and put the first emitter i found and export it...
With motion blur, it is ok.
How can i fix this? That white vertical line is very annoying and cannot found the solution.
Any help is much appreciated!
Gilles Papain
Re: white border at the right side of the image
on Feb 22, 2011 at 12:04:44 am
Same problem here.
http://www.gillespapain.com
Imre Fazekas
on Feb 22, 2011 at 12:08:43 am
Do you also use Mac version 3.08?
Imre Fazekas
on Feb 22, 2011 at 12:05:01 am
Here is the sample exported png file. By putting a black blackground, you will see clearly the white pixel column on the right hand side.
http://dl.dropbox.com/u/5999/test.png
Imre Fazekas
on Feb 22, 2011 at 12:29:53 pm
I tested it on a windows version (3.04 i guess) and it worked. Is only the mac version affected?
Gilles Papain
on Feb 22, 2011 at 3:11:23 pm
Yes i'm using MAC.
I don't have it all the time, I never had a chance to figure out when I have it and when it's fine...
But I guess it's not random...
Alan Lorence
on Feb 22, 2011 at 3:13:15 pm
In the Output Options dialog there is a button called "adjust frame". Click that and follow the instructions. Does that fix it?
Alan.
http://www.wondertouch.com
Gilles Papain
on Feb 22, 2011 at 3:15:09 pm
Will try this and let you know.
Thank you!
Imre Fazekas
on Feb 22, 2011 at 3:53:42 pm
Works, thank you a lot! :)
