Changing images in ProEmmiters?
COW Forums : Particle Illusion
Mike Schmitt
on Feb 14, 2011 at 2:54:42 pm
Hi there,
I'm finding myself using PI more and more recently with the kind of work I'm getting. I normally use the emitters strait out of the box with minor changes. This time I'd like to go a little more radical.
What I'd like to know is: Can you change the images in the ProEmmiter "Extreme Graphics, Clockwork Orange?"
Is there a tutorial for it?
Alan Lorence
Re: Changing images in ProEmmiters?
on Feb 14, 2011 at 3:05:09 pm
Changing the image in any emitter is a pretty simple thing, and it's the same procedure for all types of emitters. Here's a video tutorial on changing the image for a "text" emitter which should tell you everything you need to know:
http://www.wondertouch.com/default.asp?loadContent=vid_tut_chg_txt.asp
Alan.
