Adding new Emitter not from lib
COW Forums : Particle Illusion
Hung Nguyen
on Feb 9, 2011 at 10:44:14 pm
I'm doing a PI tutorial project, which has its own emitter. This emitter is not in the PI lib. How do I add the tut emitter to the stage?
Alan Lorence
Re: Adding new Emitter not from lib
on Feb 10, 2011 at 12:18:27 am
Is the tutorial emitter in a library file (*.il3 or *.iel)? Then just r-click in the library window, "Load library", and select the library. If it's in a project file (*.ip3 or *.ipf) then use File - Open to open the project.
Alan.
http://www.wondertouch.com
