Importing a PNG sequence without Black Halo?
COW Forums : Boris FX Particle Illusion
Matthew Stewart
on Jan 26, 2011 at 5:00:02 pm
I'm importing a PNG sequence rendered from Maya. The sequence has transparency that is perfect when viewed in Photoshop.
The problem is when I import them into PI3 the images are given a very small black halo.
Is there a setting or a step I'm missing here?
I can E-mail screen caps if it would help to clarify.
Matt S.
Alan Lorence
Re: Importing a PNG sequence without Black Halo?
on Jan 31, 2011 at 11:39:34 pm
Photoshop might be unpremultiplying the alpha channel to display it -- pIllusion doesn't do that. Does Maya have an option to output a "straight" (or unpremultiplied) alpha channel?
If not, you might be able to use Photoshop to "fix" the image by unpremultiplying the alpha channel, then saving (to a different filename to be safe). I don't use Photoshop enough to know though.
Alan.
http://www.wondertouch.com
