pI3/pIR update for Windows (IMPORTANT)
COW Forums : particle Illusion
Alan Lorence
on Jan 11, 2011 at 9:14:29 pm
I've just put the 3.0.4.2 pI3 and 3.0.7.1 pIRender (Windows only) updates back into the AutoUpdate info.
If anybody has problems installing these updates, or if you need to activate after updating, please let me know!
A few people reported problems, but most people seem to have been fine with the updates, and I couldn't reproduce any of the issues.
The pIRender update in particular is quite important, as it restores hardware acceleration to anybody who had to turn it off (ATI cards mainly).
Bob Moyer
Re: pI3/pIR update for Windows (IMPORTANT)
on Jan 11, 2011 at 11:25:32 pm
Alan,
I updated to these versions when they appeared previously and did not experience any problems during the upgrade process (I noted this in your original thread). Naturally they do not appear as an update option now. Should I be concerned? Thanks.
Bob
Alan Lorence
on Jan 11, 2011 at 11:58:29 pm
No, I just reposted the exact same versions as before, so you already have the latest.
Alan.
http://www.wondertouch.com
Mark Santella
on Jan 12, 2011 at 1:52:30 am
Yep it bombed!!!Make PI3 inoperable. Went to get new activation code and that doesn't work either. Please advise. Pretty frustrated right now. Geez
Alan Lorence
on Jan 12, 2011 at 2:48:05 am
I know you're frustrated, but saying "it bombed" doesn't really help.
When exactly did it crash? (list the steps you took before it did)
What crash message did you get (if any)? Was it a particleIllusion-specific message, or a Windows generic message?
What version of Windows are you running?
Were you running in an account that has admin priviledges?
What version of particleIllusion were you running before?
Are you saying that it needs a new activation code and you're unable to get one?
Please provide as much information as possible, or I'll never be able to fix this. Like I said originally, it works for most people, and I was unable to duplicate the problems.
It may be more helpful to send your answer to support at wondertouch dot com instead of posting here.
Alan.
Hung Nguyen
on Jan 12, 2011 at 10:06:28 pm
I can check the pI3 ver under Help, but where do I go to check the pIRender ver? I invoked the check updates and nothing came up. Does that mean my pIRender is also up to date?
Alan Lorence
on Jan 12, 2011 at 10:29:55 pm
Yes, you're up-to-date.
pIRender has a little "?" button in the lower left of the dialog.
Alan.
Craig Cooper
on Jan 15, 2011 at 8:39:24 am
My update was quick & smooth
Where can I download both from for future installs?
Cheers Craig
Peace Talks Hamper War in Middle East
Reber Clark
on Jan 15, 2011 at 5:40:13 pm
Hi Alan,
I have PI 3.0.4.1 ans PI render 3.0.7.
I tried to install the new updates and at the end of the process I received an error message:
File Damaged (is another copy already running?)
I tried again after a clean boot and got the same result.
If I recall correctly when I installed PI on my new Windows 7 Pro 64bit machine I had to change a setting in Windows or add PI to a menu inwindows to allow the thing to run. Could this be the problem?
All help appreciated. - Reber Clark
In theory there's no difference between theory and practice - but in practice there is.
John Cole
on Jan 21, 2011 at 12:24:24 am
I'm getting the same error message as Reber Clark.
Alan Lorence
on Jan 21, 2011 at 4:15:49 pm
please email support at wondertouch dot com.
Include as much detail as possible: the exact error message, when it displayed, what version you were running before the update, did you see the message immediately after downloading the update, what version of Windows are you using, are you running with administrator privileges, etc.
Basically anything you can think of that will help me.
Alan.
John Cole
on Jan 22, 2011 at 5:28:06 am
Alan,
I have sent an email to support concerning the problem. Thanks for your help.
John Cole
Francois Blawat
on Feb 24, 2011 at 6:59:30 pm
Alan,
Where can a user download these files for systems not on the Internet? Also, what does this new version fix/correct?
Thanks.
FixitMAD
Alan Lorence
on Feb 24, 2011 at 7:09:20 pm
Contact support at wondertouch dot com if you need the download links, as I haven't created an update installer yet. They'll have to be manually installed (copied).
3.0.4.3/3.0.7.2 only fixes the license reset problem that exists in 3.0.4.2/3.0.7.1.
Alan.
