Observation-Could be a problem in rare cases
COW Forums : Particle Illusion
Aaron Cross
on Dec 26, 2010 at 1:21:32 am
Hi
I used external extra monitor fo PI because it was bigger, later I disconnected it and started Particle Illusion, but PI still wanted to host the program on the (now detached) extra monitor.
Try this:(On Mac)
Use extra monitor
Drag PI over there.
Quit PI
Detach extra monitor
restart PI
> Can you actually get it to appear on the main screen? I couldn't.
Could be really bad news if it was crunch time and it was located offscreen. I guess I'd try deleting the prefs file for a start.
HTH
Cheers
AaronC
Alan Lorence
Re: Observation-Could be a problem in rare cases
on Dec 28, 2010 at 2:27:00 pm
This is a known problem. I think deleting the prefs file should fix it, but if you can verify that when you get a chance that would be helpful.
Alan.
http://www.wondertouch.com
