Copying il3 files to Emitter directory
COW Forums : Particle Illusion
Francois Blawat
on Nov 16, 2010 at 9:35:46 pm
Hello,
Maybe I'm missing something but I found some older .il3 files that I had on CD and when I copy them to my Emitter Libraries, I cannot find them by using the Load Library button within partilceIllusion. I see all the other libraries, but I cannot figure out how to activate these so they are present. I am using Windows with the latest version of pi3 (3.0.4).
If I select Load and manually point to another folder I can load up the libary but they do not seem to be loaded up when I start pi3.
The .il3 files that I have copied over to my c: drive are fully read/write. I removed the read only restrictions on them.
Thanks.
FixitMAD
Alan Lorence
Re: Copying il3 files to Emitter directory
on Nov 16, 2010 at 10:00:52 pm
Are you running Vista or Windows 7? Then it's probably not putting the files where you think it is -- writing to the Program Files folder (and subfolders) puts things in another folder.
Does anybody know if there is a way to work around this in Vista or Windows 7?
Alan.
http://www.wondertouch.com
Francois Blawat
on Nov 16, 2010 at 10:04:30 pm
Wow, ok. Nevermind.
I should have double-checked my directories. For some reason I had an older folder that my libaries were copied to. I have since moved them to the correct folder and now all my emitters are now showing up under the Load Library function.
Sorry for the post.
Thanks.
FixitMAD
