adding frames to an *open* ip3 file.
COW Forums : Particle Illusion
Scott Mathews
on Oct 22, 2010 at 10:50:02 pm
Hey tx for your software; very cool and making a better game for it.
Sort of a noob question:
Is there any way to add frames to a .ip3 file that is already open?
I know I can go under prefs and set the frame count there. But that won't propagate until I create a new file. I am looking to extend the total frames on an existing .ip3 file.
Tx again,
S-
Alan Lorence
Re: adding frames to an *open* ip3 file.
on Oct 23, 2010 at 2:23:41 pm
Use the playback toolbar, or "Project Settings".
Alan.
http://www.wondertouch.com
Philip Knight
on Nov 14, 2010 at 2:12:56 am
Once you change it in Preferences, make sure you change the "loop" window next the frame position boxes to match the number you put into the Preferences. Otherwise it will just run and show the old range.
Alan Lorence
on Nov 15, 2010 at 3:30:14 pm
Just to be clear, the "Preferences" values will be used for every New project.
You can change it in the current project using the playback toolbar as suggested or in the Project Settings dialog.
Alan.
