Adding a new emitter library to SE
COW Forums : Particle Illusion
Jason King2
on Oct 19, 2010 at 1:50:42 am
Forgive my ignorance, but I have not used pi se in about 4 years and I cannot find any direct way to simply just add a new emitter library from the wondertouch website. I right click and select load library I get emitter properties in library window, but from here I see no way to add a new library. Can anyone shed some light on what I may be doing wrong here, I thought I was able to do this some years back when I first used the program.
Jason King2
Re: Adding a new emitter library to SE
on Oct 19, 2010 at 3:14:29 am
Ok, first since I haven't posted here in awhile, sorry for the dual posts - my bad. 2nd, I figured out my problem, I just needed to do a clean install.
Craig Cooper
on Oct 19, 2010 at 8:41:16 am
Just copy the il3 files to the \program files\particleillusion 3.0\Emitter Libraries folder. Thats all you need to do to add the latest emitter library.
Cheers Craig
Peace Talks Hamper War in Middle East
