PI plugin for AE
COW Forums : Particle Illusion
Doug Brown
PI plugin for AE
on Sep 29, 2010 at 11:18:56 pm
I want to have my PI effects that I create in AE using the PI plugin on their own layer to render in separate passes. How can I achieve this?
So far I have tried...
-Applying PI to a solid layer, but it doesn't auto alpha out the solid.
-Applying PI to an adjustment layer, but I still need a background image to see the effect and therefore, can not render out a separate pass for the PI effect.
Please help!
Alan Lorence
Re: PI plugin for AE
on Sep 30, 2010 at 4:55:27 pm
What are you trying to achieve with the separate passes?
The "not removing alpha" when applied to a solid *is* a limitation with the current version.
Alan.
http://www.wondertouch.com
