PL and Sony Vegas?
COW Forums : Particle Illusion
Parker Small
PL and Sony Vegas?
on Sep 1, 2010 at 9:42:49 pm
I need to make some thing i rendered in Pl transparent, for example i need to make a particle video with some swirly lights blend with a video clip in sony vegas so i can see the particles and the video at the same time. i have sony vegas platinum 8 and Pl 3.0
Philip Knight
Re: PL and Sony Vegas?
on Sep 2, 2010 at 9:56:43 pm
I work in Vegas Pro 8 but PI export that works is the same:
-- Choose file type for export as .PNG,
-- Create a folder in which the sequence will be made,
-- Name particle sequence.
Once the Output Options window comes up:
--- Choose desired length of sequence (the default number usually is the playback range you are using, so if you want shorter or longer, specify the "End frame".
-- Select "Save Alpha" and "Remove black from RGB channels," hit "OK."
NOTE: If you are rendering from within PI-3, you cannot have any window or program running over or covering PI or have it minimized for it will interrupt/stop the output render. On the other hand, the PI Render program can run in the background or minimized.
