PNG Animated Cursor Overexposure
COW Forums : Particle Illusion
Jay Inglee
on Apr 21, 2010 at 8:52:09 am
HI
Relatively new to using PI and am experimenting with creating animated cursors (CursorFx).
The PNG is made in Photoshop, effects added in PI and exported into CursorFx for (Busy and working in background states).
My problem is that the animated sequence seriously overexposes the cursor.
In PI, the emitter effect looks great.
Only after applying the cursorin Cursor FX, the animation removes the detail and color from the cursor image.
I have tried using separate layers (under and on top of PNG) and niether works well.
Any help is appreciated.
Alan Lorence
Re: PNG Animated Cursor Overexposure
on Apr 21, 2010 at 12:54:28 pm
This isn't a particleIllusion issue.
Is CursorFX converting it to 256 colors or something? Does the rendered output of particleIllusion look OK? If so, then maybe convert the pI output into 256-color using a different application first.
Alan.
http://www.wondertouch.com
Jay Inglee
on Apr 21, 2010 at 8:36:11 pm
HI
Thanks for the reply.
In PI, I am just saving the animation as a PNG, Save Alpha, Remove Black.
Have tried saving the PNG as 256, 24 and 8 bit with the same results.
posted a screen shot -
The two center images are obviously the working-animated states.
Thanks again for any feedback.
