Handle long clips?
COW Forums : Particle Illusion
Hamid Rohi-Bilverdy
Handle long clips?
on Apr 18, 2010 at 1:44:43 pm
Hi..
What is the approch or the "best" way to import a clip I edited in after effect and then export it, so I can give it a final touch inside after effect again?
If the clip from after effect is a long one, and I only need to edit some small sections of it in pI3, how do I dp this? Because pI3 canĀ“t handle long clips ??
Please advice
Alan Lorence
Re: Handle long clips?
on Apr 19, 2010 at 12:48:11 pm
This is an After Effects question, not a particleIllusion one. In AE set the work area to the clip you want to export, export using a lossless codec or image sequence, then use that in particleIllusion as reference. Then render the particles alone with an alpha channel, load that into AE and composite.
Alan.
http://www.wondertouch.com
Hamid Rohi-Bilverdy
on Apr 27, 2010 at 12:17:19 pm
Thanks Alan.
Is there a way in pI, when i import my eksported clip from AE, for pI to auto calculate the frames?
When I imported my clip, I did not know the exact frames, so when i am done in pI and want to import the clip back into AE, I want the frames to be accurates as the clip I eksported.
Please advice.
