Retaining quality in export?
COW Forums : Particle Illusion
Mark Mora
on Jan 27, 2010 at 4:53:33 am
Hi, what are the best settings to retain the quality of the background video in your project? I made a stop motion animation, and when I exported it, the quality was fine. Then I added the effects and exported it. The video quality decreased, but the effects quality was really good. Help?
Philip Knight
Re: Retaining quality in export?
on Feb 15, 2010 at 7:43:39 am
An old posting, but I figure
I'd leave a response anyway...
Not knowing if you use a PC or Mac, or the format, codec or compression level you original BK footage was, hard to give you an instant answer.
But here may is perhaps the best way to do it as others do also:
-- I use a PC and my NLE is Sony Vegas Pro -- I very rarely export both BK and emitter work together because I want the BK original footage to be in its best original form (as it is in my NLE). So I hide the BK and export only the emitters layer/s as a PNG image sequence with alpha. This preserves the quality of the emitters since PNG format is lossless.
-- Then I put the emitters on a track above the original footage in my NLE. This gives me additional tweaking and improvement parameters due to all the fx, color, etc. effects in the NLE. I usually always find a way to improve the appearance of emitters. Once in a while, I'll even double emitter tracks at different transparency levels which gives even more control over appearance.
Win-win: Original footage preserved, emitters appearance can be fine-tuned a bit more.
Paul Wright
on Mar 6, 2010 at 2:57:26 pm
I am having a problem trying to render a PNG sequence much in the manner you described. This is how I want to do it for exactly the reasons you mentioned (ability to tweak individual emitters, etc, after re-importing to the NLE). However, my alpha PNGs come back very 'dirty' looking in Sony Vegas. The edges are darker and blotchy. Doesn't seem as transparent. How do I get it to retain it's original clarity over the footage? If I render from PI and leave the background intact, the final looks great. If I hide the background, and try to do a PNG with alpha, it doesn't look right when I re-insert over the same footage in Vegas. What am I missing? Any ideas?
© 2018 All Rights Reserved
