foam emitter in PI3
COW Forums : Particle Illusion
Jim Woodruff
foam emitter in PI3
on Jan 6, 2010 at 2:21:42 pm
Does anyone know of a particular emitter in any of the current libraries that would look like foam? I'm thinking of the type of foam you would see from a "foaming bubbles" sort of bathroom cleaner / sprayer. I need to illustrate a drain cleaner foam that would travel down a straight section of pipe then dissipate.
Thanks for any suggestions.
Jim
Alan Lorence
Re: foam emitter in PI3
on Jan 7, 2010 at 9:24:35 pm
I tried making one in the just-released December emitter library.
Alan.
http://www.wondertouch.com
Jim Woodruff
on Jan 7, 2010 at 10:22:45 pm
Alan,
I downloaded the library and I think the emitter will give me a starting point to work from.
Jim
Graham Bernard
on Jan 15, 2010 at 6:17:25 pm
Alan! You have surpassed yourself! Excellent work.
Those Blue and Orangy flames, blended together are amazing!
Thank you,
Grazie
