Second/Home Network Computer = Faster PI?
COW Forums : Particle Illusion
Philip Knight
on Nov 25, 2009 at 10:01:28 pm
I've toyed with this idea for a bit but don't know enough about it.
The basic question is:
A -- Can one substantially lighten the load on PI (and/or an NLE) by hooking up another computer as extra CPU muscle?
B -- If so, how and - what would be the most affordable way to go?
This is kind of a segue from previous issue of slow FPS due to background videos in PI. So the prequel question to even considering this idea would be:
-- Would such a setup actually help improve this situation or not?
My current one stand-alone system specs are:
- XP Home 32 bit
- Pentium D 2.8 Ghz
- As much RAM as 32 bit allows < 4 Gb.)
- Multiple 7200 rpm SATA2 drives
Thanks.
Alan Lorence
Re: Second/Home Network Computer = Faster PI?
on Nov 29, 2009 at 2:15:14 pm
No. There's no distributed rendering in pIllusion.
Alan.
http://www.wondertouch.com
Rob Holmes
on Oct 30, 2011 at 12:27:21 am
But is there Network Rendering? You say no "Distributed Rendering." I can't get PI to work with my AE 5.0 Render Queue Jobs sent to my farm machines. I get blank frames. I've run the installation on my farm machines and it appeared to go just fine. I tried to activate those nodes but nothing happened. I tried to Manually Activate those Hosts on the Activation Site and it said it couldn't find the Activation Code.
How do I set that up please? I guess I should have asked that question before I purchased the app last night to finish up a job.
Asus P5K-Deluxe - Intel Core2 Extreme QX6850 - 8GB DDR2 1066Mhz -ATI FireGL V8600 - 3D Studio (preMax) thru Max 2011 Design
Alan Lorence
on Oct 31, 2011 at 12:24:46 pm
The previous poster was talking about the standalone application version of particleIllusion.
In After Effects you should be able to use pI on your farm without activation. I assume you mean AE CS5, not AE 5.0, right?
Alan.
Alan Lorence
Product Manager
GenArts, Inc.
http://www.genarts.com
Rob Holmes
on Oct 31, 2011 at 2:44:28 pm
Yes, AE CS5. I think we are already talking privately. I appreciate it. I'll try your suggestions:
Try two things:
1) Delete the emseldata.dat file that is in Documents/wondertouch/pIAE
2) Reset your AE prefs. Restart AE while holding down the Command + Option + Shift keys (Mac) or Control + Alt + Shift (Windows), and you are presented with an option to delete the preferences.
Then open AE, add pIAE and things should be back to normal (emitter selection dialog should show).
