Leaky Deflector
COW Forums : Particle Illusion
Toby Welles
Leaky Deflector
on Nov 19, 2009 at 2:21:19 am
Hi, I'm having a problem with particles leaking through the deflector. should I create more points in the deflectors, make the the thickness greater or add another deflector in the same location. I want to keep the efficiency high, and the deflector has to be curved. I am trying to simulate a jet of particles flowing around in circular shape like an eddy by using a curved deflector and several forces to blow the particles along the path. I sure wish there were circular and or vortex force objects (Hint Hint)
Thanks.
Toby Welles, wowhouse.net
Alan Lorence
Re: Leaky Deflector
on Nov 19, 2009 at 4:58:19 pm
A couple of things to try:
1) put another deflector close behind it, but don't have the "corners" in the same place. (not a great solution)
2) use only forces
Unfortunately, you're trying to do something that pI3 does not have tools to do very easily.
Alan.
http://www.wondertouch.com
Toby Welles
Re: Leaky Deflector
on Nov 19, 2009 at 6:03:54 pm
I'll just muscle through. Is this an area that you will be incorporating onto the next version perchance?
I love to be able to do this sort of thing in PI rather than resort to a full 3D system which takes so much longer.
