To reset emitters to default?
COW Forums : Boris FX Particle Illusion
Kurt Muller
on Sep 23, 2009 at 7:23:55 am
Guys, if you alter the properties of an emitter and add it to the library, how can you go back and reset it, if you don't remember its original settings?
Kurt.
Alan Lorence
Re: To reset emitters to default?
on Sep 23, 2009 at 8:08:53 pm
There is no way. The library emitters are the "default" state. If you've overwritten a library emitter, you'll need to download the library again.
Alan.
http://www.wondertouch.com
Kurt Muller
on Sep 24, 2009 at 1:08:45 am
Okay, thanks, Alan.
I guess I'll have to be careful not to save modified emitters by the original name.
Cheers,
Kurt.
Alan Lorence
on Sep 24, 2009 at 11:56:52 am
The name doesn't matter. You can have 20 emitters in the same library that have the same name.
If you added a library emitter to the stage, edited it on the stage, then used "add to library", you'll still have the original in that library too -- unless you deleted it from the library.
Alan.
Kurt Muller
on Sep 24, 2009 at 11:46:55 pm
Aah, good! Thanks, Alan. I'll make a note of that.
Kurt.
