.IP3 Project: How to Go from SD > HD Without Total Re-Do
COW Forums : Boris FX Particle Illusion
Philip Knight
on Sep 12, 2009 at 4:53:30 pm
Original project: SD 720x480
New Working Size: HD 1440x1080
Is there a way to in essence "zoom up" everything within the project, from particles to blockers, etc. to fit new desired HD format without having to start from scratch? Right now, all project elements are obviously too small in the new .ip3 since they were initially designed for its original, earlier SD or 720x480 size.
Thanks.
Alan Lorence
Re: .IP3 Project: How to Go from SD > HD Without Total Re-Do
on Sep 14, 2009 at 2:39:43 pm
Yes. In the Action menu, choose "Scale Project".
Keep in mind that for best visual results with some emitters you may want to tweak the emitter a bit -- just scaling it up doesn't make it more HD-like. For instance, if you have a sparkle trail fairydust-style emitter at SD, when going to HD you probably don't want bigger particles, you probably want more of them (to take advantage of the higher resolution).
Alan.
http://www.wondertouch.com
Philip Knight
on Sep 14, 2009 at 7:07:35 pm
Thanks. That's a relief, and your tweak note is duly noted.
