Emitter Effects Behind A Subject?
COW Forums : Particle Illusion
Ray Jender
on Aug 19, 2009 at 7:28:17 pm
New user playing around with PI.
How do you use an emitter and have it's effects go behind a subject on a video?
For instance in the ballerina example, the sparkles can be seen in front of her,
but also, they are behind her.
Ray
Rob Dahl
Re: Emitter Effects Behind A Subject?
on Aug 19, 2009 at 8:56:28 pm
Well that would depend on your footage and scene setup.
You could:
Set up a blocker that is animated like the dancer in PI.
You could rotoscope the dancer and place the effect behind the roto's layer.
If the dancer is filmed on a chromascreen, use layers to control the effect... similar to rotoscoping.
Other please weigh in... if there is a better route to take.
Rob Dahl
Transparent Alchemy
Boulder City, NV 89005
http://www.transparentalchemy.com
