PI3 Emitter Library folder do not display new downloads
COW Forums : particle Illusion
Ann Ari
on Aug 8, 2009 at 1:28:16 pm
Hi, I have noticed since I have updated PI3 in the Program folder of Emitter Library I can not see the downloaded library such as emitters_09_06.il3,emitters_09_07.il3, and old _user_ best.il3. But from PI3 software when I access library I can locate above three files.
The only reason I want to see these files in program/emitter library is because I wanted to drag two 2009 updates in the folder of 2009 which I have assigned. However, I have manually copied the two libraries.
But I still want to know why I can not see two libraries as mentioned above in the Emitter library folder.
And how can I download old _user_ best.il3
Your reply in this regard will be appreciated.
Thank you
*** I wonder if you ***
