How do you stop particles?
COW Forums : Boris FX Particle Illusion
Ceira Peachy
on Jul 24, 2009 at 1:42:50 pm
Ok, Is there a way to make particles rise up until a certian point, stop for a period of time, and then continue?
I also need the velocity to stop at the same time, but look exactly how it did befor it stopped. only it stops exploding.
Theo van Laar
Re: How do you stop particles?
on Jul 25, 2009 at 1:50:02 pm
If you want your particles to stop at the certain point, you can make the velocity over life zero at a certain timepoint. Make sure that the velocity variation is set to zero.
Theo
Ceira Peachy
on Jul 25, 2009 at 8:09:40 pm
thanx, I'll try it. If it doesn't work..I'll ask again. XD
