Camera shake
COW Forums : Boris FX Particle Illusion
jamie young
Camera shake
on Jul 15, 2009 at 3:11:55 pm
I only use PI for my effects. I was wondering if anyone knows a way to simulate a camera shake.
please and thank you.
Jamie.
Alan Lorence
Re: Camera shake
on Jul 16, 2009 at 2:19:19 pm
You can use "record position" to manually move around an emitter, then export that position data to the clipboard. Then you can select the "Layer Offset" and import the position data from the clipboard and the layer will now have this "shaking" motion.
BUT... any background images won't be affected by this. So if you want to shake your footage and your effects, you'll need to use another application most likely.
Alan.
http://www.wondertouch.com
Theo van Laar
Re: Camera shake
on Jul 19, 2009 at 2:36:46 pm
A good program to obtain the camera-shake is VideoShaker from Prodad.
http://www.prodad.de/gb/mercalli_std_details.html
Theo
Peter Friend
Re: Camera shake
on Aug 12, 2009 at 9:13:54 pm
The web site says it's included in the demo version of Mercalli, but also notes this demo version puts a red cross on output - does anyone know whether the red cross appears in the Video Shaker output?
Theo van Laar
Re: Camera shake
on Aug 16, 2009 at 12:50:21 am
I only can tell you that the red cross will not appear in the registrated version of VideoShaker.
Theo
