In SE Particles Don't Show On Playback
COW Forums : Boris FX Particle Illusion
Kerry Cramer
on Jul 3, 2009 at 10:12:14 pm
It seems that after I put in an emitter (as per directions), the only way I can see the particle effect is to start then stop the playback in quick succession. Then I get a still image of the effect...but even that only works ~20% of the time. What am I doing wrong? (The demo did the same thing about half the time.)
Alan Lorence
Re: In SE Particles Don't Show On Playback
on Jul 6, 2009 at 2:03:10 pm
I'm thinking this may be an OpenGL issue. You're on Windows, right? Use the "run with software rendering" option in the Start - Programs - particleIllusion 3.0 - troubleshooting menu.
If that works, then you need to download the latest video drivers from your graphics card manufacturer's website.
Alan.
http://www.wondertouch.com
Kerry Cramer
on Jul 7, 2009 at 2:05:40 pm
That seems to have solved the problem...Thanks!
