shapes from other libarys
COW Forums : Particle Illusion
samuel kent
on Jun 27, 2009 at 6:39:56 pm
i was just wondering if there was some way to take a load of shapes from other libary's to put into a blank one, because its really annoying having to make my own ones, and this would be EXTREMELY useful
thanks in advance,
sam k
John Holste
Re: shapes from other libarys
on Jun 28, 2009 at 2:09:21 pm
Sam,
one way is to use the "properties" dialog in the Library window, click the "Particles" tab and "Change Shape" tab, just select the Shape you want to copy and export it(the diskette shaped icon), repeat this for every shape you want to copy, then open up your "blank" library and load(the folder with a +) the exported shape(s).
a second way is to use the "Manage" function to copy an emitter that uses the "shape" you want to a blank library, then delete the emitter using the "properties" function.
John
samuel kent
on Jun 28, 2009 at 5:48:45 pm
thanks for that, really helpful
