How can I automatically change emitter libraries from within Particle View?
COW Forums : Boris FX Particle Illusion
Tia Bradford
on Jun 20, 2009 at 10:35:06 pm
Is it possible to view the entire emitter library from Particle View? If I hit Left and Right arrow keys I can scan through a single emitter library, but I cannot scan the entire library of emitters. Have I done something wrong, or do I have to load every library separately to view it?
John Holste
Re: How can I automatically change emitter libraries from within Particle View?
on Jun 22, 2009 at 12:25:26 pm
Tia,
you can do an empty search in particleView and then click each emitter in the list. To do an empty search press the "S" key to bring up the search window, leave the search textbox empty, be sure to click the "Or" option and the click "Search".
Have Fun,
John
Tia Bradford
on Jun 22, 2009 at 1:53:51 pm
Thank you very much. I will try this solution.
