Trouble setting background animation images
COW Forums : Boris FX Particle Illusion
Leigh Young
on Jun 9, 2009 at 7:36:24 pm
I'm having problems setting the background as an animation. When I select background image, I then select 001.png of 65 pngs in the same folder. But when I click open it just reopens the window I was just in to choose an image. I choose 001, 010 or even the last file in the sequence but to no avail. This problem is with pngs and jpegs. Sometimes I can work around it but other times I really do need to see the animation I'm putting the particle with. Restarting the program doesn't help.
Alan Lorence
Re: Trouble setting background animation images
on Jun 9, 2009 at 11:57:55 pm
Don't use only numbers in the filenames. If you use "image001.png", "image002.png", etc. it will work fine.
Or even "a001.png", "a002.png", etc. It just needs something before the numbers.
Alan.
http://www.wondertouch.com
