Video Length Issues
COW Forums : Particle Illusion
Franz Vorenkamp
Video Length Issues
on Apr 23, 2009 at 5:09:43 am
I am exporting a video from after effects in uncompressed AVI format.
It is 75 seconds long, or 1800 frames.
When it is imported into particle illusion, it seems to misinterpretation the video- the end comes at frame 900, even when it is set to 24 fps like that video.
What gives?
I wish that after effects plugin would come out. This is very annoying to deal with- the moving in and out between programs.
John Holste
Re: Video Length Issues
on Apr 24, 2009 at 12:57:40 pm
Franz,
I have never used an uncompressed avi I wonder if that is the issue? Try a lossless compressed avi, if you are worried about quality issues.
John
John Holste
on Apr 24, 2009 at 12:59:34 pm
Franz,
Quote from Alan "...Lagarith uses lossless compression (like a ZIP file). Uncompressed just doesn't make sense..."
John
Theo van Laar
on Apr 27, 2009 at 9:57:03 pm
John,
I don't understand your comment to Franz about uncompressed avi. The problem of Franz is that his output file is only half the expected length. I see exactly the same in PI 3.0.4.1: the output file is only half the length as would be expected from my settings. I'm working in PAL and use the Lagarith codec.
I hope that Alan Lorence has a solution for this.
Theo
Alan Lorence
on Apr 27, 2009 at 10:18:07 pm
If you have a 30 frame video, does pI3 see it as 15 frames long?
Is it a fields issue? (Try rendering in AE without fields and see if that fixes it.)
Alan.
http://www.wondertouch.com
Theo van Laar
on Apr 28, 2009 at 4:59:28 pm
No, it is not a field issue. I will rebuild the project from scratch and see if that solves the problem.
Theo
