A Diffuse clip and an alpha clip - Now how do I do that at the same time?
COW Forums : Particle Illusion
Aaron Cross
on Apr 14, 2009 at 11:03:52 am
Hi folks,
Im going to try and export some video to use in Poser Application on a flat plane.
I understand I need the video in two clips, much like a normal alpha channel functions, One videoclip is to be diffuse, and the other a black and white mask videoclip. Apparently thats the Poser way...
So how best to do this?
Thank you for any advice. I didnt see anything in the help files.
AaronC
Alan Lorence
Re: A Diffuse clip and an alpha clip - Now how do I do that at the same time?
on Apr 14, 2009 at 1:49:07 pm
You can get a greyscale (black and white) rendering by turning on display of the alpha channel in the stage window and rendering that way. Don't "save alpha".
You'll end up with the alpha channel data in the RGB channels.
Make sense?
Alan.
http://www.wondertouch.com
