help with snow
COW Forums : Particle Illusion
mark cas
help with snow
on Mar 29, 2009 at 8:34:27 pm
the program closes and says program not responding when i use the snowstorm effect..........and when i use the simple snow effect it plays really really really slow
Alan Lorence
Re: help with snow
on Mar 30, 2009 at 9:41:51 pm
If I remember right those are both area emitters, meaning you draw a rectangle and particles are created throughout that rectangle. The larger the area, the more particles are created. Here's what I suggest:
1) add the area emitter to the stage, but make the rectangle small. Much smaller than you need it.
2) Adjust the emitter "number" graph to 1%
3) Now make the rectangle larger (either by dragging its "handle" on the stage, or changing the "width" and "height" values)
4) When you get it to the size you want, you may have to increase that number value up a bit to fill in the way you want it.
If it's still creating too many particles, even when set to 1%, you will also need to decrease the "number" value for each particle type.
Hope this makes sense.
© 2018 All Rights Reserved
