Exporting Loop Problem - Save Alpha
COW Forums : Boris FX Particle Illusion
David Arcila
on Mar 20, 2009 at 10:06:18 pm
Hello!
I did a loop following the famous loop tutorial, now i want to export that loop as a sequence of images (png's) with transparent background, but when i export the images with the Save Alpha option checked Particle Illusion exports the entire timeline, but when i do the same export but without the Save Alpha option, it exports the way i like it (just the loop) but without transparent background :(
I hope i made myself clear, if not, i could post images with a detailed explanation.
Thank you
Alan Lorence
Re: Exporting Loop Problem - Save Alpha
on Mar 23, 2009 at 10:19:53 pm
So the only thing you changed was checking or unchecking "Save Alpha" -- absolutely nothing else was changed?
Alan.
http://www.wondertouch.com
David Arcila
on Mar 24, 2009 at 1:51:03 am
Alan, thanks for your response.
That's right, the only thing that changed was the Save Alpha parameter.
