Stage Size Not retainng setting?
COW Forums : Boris FX Particle Illusion
Reber Clark
on Mar 14, 2009 at 4:49:33 pm
Hi.
I render an AVI in square pixels from a widescreen Vegas project to use as a reference for my PI work. I render it at 873x480. It looks great in PI and my stage setting (project setting) in PI is 873x480 so I don't need to resize anything.
I do the FX work and after removing the background (not just turning it off) I render a Lagarith .AVI file saving the Alpha and removing the black.
My question is on the Lagarith Output options under "output size" it says "Output Size Set by project settings - 876x480." But my Project settings are 873x480. I cannot find why this is happening. Any ideas welcome!
Alan Lorence
Re: Stage Size Not retainng setting?
on Mar 23, 2009 at 10:26:52 pm
Render as a PNG image sequence instead. Many (most?) AVI codecs don't support weird widths -- they need widths that are a multiple of 4 (or 8, or 16 -- I can't remember which).
Alan.
http://www.wondertouch.com
Reber Clark
on Mar 23, 2009 at 10:59:25 pm
Alan, Thanks for the response. The reason I am using 873x480 is that when I export a "snapshot" image from my NTSC Widescreen (1.222)Vegas timeline, that is the measurement that results. I can work with PI's 876x480 just fine, however. Thank you for the additional info on .AVI idiosyncrasies!
In theory there's no difference between theory and practice but in practice there is.
