Using NOT black background?
COW Forums : Particle Illusion
Steve Stryker
on Mar 6, 2009 at 11:57:16 pm
Hi again,
Ok I am still very much a noob at all this.
I am doing a chroma key project.
I have the keying done well.
I am using Sony Vegas Pro 8
For the background I am using "cloudy sky"
Proble: the particle Illusions look washed out on the white background. Is there (what) am I missing or not setting up correctly?
Steve
Sony Vegas, Particle Illusion, NOOB!
Alan Lorence
Re: Using NOT black background?
on Mar 9, 2009 at 2:15:57 pm
I'm not sure as you haven't given enough details, but try these things:
- In particleIllusion, render on black background, then when you check "save alpha" in the output options dialog, make sure "remove black..." is checked.
- You can edit the properties of the emitter itself -- double click it on the stage to open the properties dialog, then click the "particles" tab, and check the "preserve color" option that's next to "intense".
Alan.
http://www.wondertouch.com
Steve Stryker
on Mar 11, 2009 at 7:14:29 pm
Thanks, I will try them. I have some time in the next few days.
