Render Tips
COW Forums : Particle Illusion
Gabo Kerlegand
Render Tips
on Feb 26, 2009 at 2:32:28 am
Hi, I'm trying to render a HD output (1920.1080), but I'm working in a 17 inch monitor 1600 by 1200, and I can not render the full HD, it tell me that only "limited stage window size", how can I change this... Any sugestion...
Thanks a lot
cowcowcowcow
Ra-ey Saleh
Re: Render Tips
on Feb 27, 2009 at 12:53:57 am
Anything over your visible monitor screen size (i.e. HD) needs to be rendered in pIllusionRender (which should have installed with pI).
Just save your project in pI, open pIllusionRender, set your settings and export.
Alan Lorence
Re: Render Tips
on Feb 27, 2009 at 2:07:19 am
If you're using the latest version of pI3, pIRender will be called automatically when needed -- no need to call it manually.
Alan.
http://www.wondertouch.com
