Particleillusion SE
COW Forums : Particle Illusion
Ann Ari
Particleillusion SE
on Feb 10, 2009 at 3:23:18 am
Hi, I am very much impressed by your products and I want to buy if you clear the follwing questions please:
1. Will it work on windows vista 34 bit Japanese OS?
2. DX AVI is not supported then which video format it can support?
3. It Got no restriction of Derivative work done by using your software such as, in commercial use or posting on web etc?
Please reply and oblige
Thank you
Ari
Alan Lorence
Re: Particleillusion SE
on Feb 10, 2009 at 10:52:59 pm
It should work fine in Vista 64-bit.
DV AVI *is* supported.
There are no restrictions on using the rendered output of particleIllusion.
Alan.
http://www.wondertouch.com
Ann Ari
on Feb 11, 2009 at 2:16:48 am
Hello Alan,
I have windows vista premium home 34 bit not 64 even in this case it will work fine? And OS is Japanese.
Thank you
Ann Ari
on Feb 11, 2009 at 8:10:27 am
Further to my last post. I have installed demo version 3.0.41, 5Jan 2009. Working fine on windows vista premium 34 bit( I guess). I did some experiment and they are great. I am impressed by this soft.
Would you mind telling me what to do if want to increase the duration/time of the project example: if it is 15 or 20 second can I make it longer duration one or two minutes before saving in to wmv? avi had showed error.
Thanks for support
