How do I get to particleView's "emitter search feature"?
COW Forums : Particle Illusion
Graham Bernard
on Feb 4, 2009 at 8:06:44 pm
I can see particleView, use it all the time, but the "search" feature? - Not so much . . . .
TIA
Grazie
Alan Lorence
Re: How do I get to particleView's "emitter search feature"?
on Feb 4, 2009 at 8:16:58 pm
Press the "S" key when particleView is open. This works in both the Win and Mac versions of pView.
You can do some other things with pView too -- press F1 on the Windows version for a list of all commands. On the Mac version, just look at the commands in the "Emitter" menu. Note that on the Mac version you can use CMD+whatever key as well as just the key alone (so cmd+S and S both bring up the search window).
Alan.
http://www.wondertouch.com
Graham Bernard
on Feb 4, 2009 at 9:26:03 pm
Thanks Alan.
2 product suggestions?
1] Make it possible to change properties of "found" emitter thru Emitter Search
2] Drag and drop Emitter directly from Emitter Search into PI.
Grazie
