Particle View Crashes on Search
COW Forums : Particle Illusion
Richard Lyall
on Jan 9, 2009 at 4:13:48 pm
Whenever I perform a search in ParticleView, I get the following error, and PV quits.
"Microsoft Visual C++ Runtime LIbrary
Runtime Error!
C:Art SoftwareParticle Illusion SEParticleView.exe"
It worked before, but something has obviously changed. Is this a known issue?
Richard
Richard Lyall
http://craftycurate.blogs.com
John Holste
Re: Particle View Crashes on Search
on Jan 9, 2009 at 8:11:45 pm
Richard,
Make sure you have the latest version 3.2.2. You may need to rebuild the index, delete all files in:
"C:Documents and SettingsAll UsersApplication DatawondertouchparticleView"
and
"C:Documents and SettingsAll UsersApplication Datawondertouchsearch data"
Then rerun particleView, you should get a "building index" window with a progress bar.
John
cowcowcowcowcow
Richard Lyall
on Jan 9, 2009 at 9:00:38 pm
That's sorted it, thanks.
Richard
Richard Lyall
Graham Bernard
on Nov 20, 2009 at 8:32:39 am
Just needed to do this! Thanks John, result.
Grazie
