Particle Illusion Hangs after update to 3.0.8 (Mac OS X)
COW Forums : Particle Illusion
Albert Kiefer
on Jan 6, 2009 at 9:37:40 am
Yesterday I updated my Particle Illusion to the latest 3.0.8 on Mac OS X. I validated via the online page and after that Particle Illusion crashed. I restarted the application and it then wants me to point it to an emitter library. However the startup screen stays open and whatever I do I cannot actually select a librarie via the file browser so the app stays waiting forever and I can't start working.
Is there a way to reset the whole application? Or does anybody know what I should do to fix this?
Thanks in advance,
Albert Kiefer
Alan Lorence
Re: Particle Illusion Hangs after update to 3.0.8 (Mac OS X)
on Jan 6, 2009 at 12:11:47 pm
Delete your preferences file:
/ Library / Preferences / pIllusion3.prefs
That should fix it.
Alan.
http://www.wondertouch.com
stan miskiewicz
on Jan 21, 2010 at 1:40:56 am
There are PI files in the Prefs folder!?
I deleted PI and did a new install
same thing
starts to open
hangs
looking for emitter library
in a folder called MacOS
which I can not find
thanks
stan miskiewicz
on Jan 21, 2010 at 2:21:04 am
Well for me it was because I unpluged my mac from the server network I have.
when I plugged the mac back into the router it worked.....????
it works thats all I want
Stan
Alan Lorence
on Jan 21, 2010 at 1:56:02 pm
It's probably stuck trying to look for updates. It should know that there is no Internet connection available, but it may be that the timeout period is too long.
It may also be related to the problem where it won't see any updates or emitter libraries available on OS X (Snow Leopard only?).
You should turn off the "check for updates" option in the preferences if you're not going to keep it connected to the Internet.
Alan.
