PI SE Hierarchy
COW Forums : Particle Illusion
David Davis
PI SE Hierarchy
on Dec 9, 2008 at 7:40:47 pm
I've got 3 effects in my stage window. I go to the Hierarchy window and change the sequence of the effects. (from 1-2-3 to 3-1-2 or such) by using the Move up/down option. When I play back the frames the sequence of effects never change.
What am I doing wrong or is there some other issue?
David
Alan Lorence
Re: PI SE Hierarchy
on Dec 13, 2008 at 12:27:10 am
This will change the layering of the effects -- the one on top in the hierarchy is the one on top in the stage window.
For some emitters this will make no difference, as the particles will be blending together ("intense" particles are additive).
Alan.
http://www.wondertouch.com
